Knowledge Base Article
Can the frequency of the PLL output clock change after manual clock switchover?
Description
Yes, depending on the secondary input reference clock frequency that user is switching to, the PLL output clock frequencies can change. This is because the PLL counter settings will remain constant during the manual clock switchover and therefore the new output clock frequency will be based on the new input reference clock and the PLL counter settings. For example:
Settings from the altpll megafunction
Inclk0 = 20 MHz
Inclk1 = 18 MHz
Output = 100 MHz
N counter = 1
M counter = 30
Post scale counter = 6
VCO = 600 MHz
In this case, when the input clock is manually switched from inclk0 to inclk1, the new output frequency is now 90 MHz rather than 100MHz based on the above settings.
Note that changing the input frequency may cause the PLL to lose lock, but as long as the input clock remains within the minimum and maximum lock range frequency, the PLL will be able to achieve lock.
Refer to the respective device handbook for more details and guidelines for using manual clock switchover.
Related Articles
Updated 1 month ago
Version 2.0
