Knowledge Base Article
Can the FPGA to HPS bridge be reset (f2s_bridge_rst_n) from the Hard Processor System on the Intel® Stratix® 10 SX device?
Description
No, the FPGA to HPS bridge must not be reset from the software.  The following corrections are being made to the documentation.
Issue 530449:   Intel Stratix 10 Hard Processor System Technical Reference Manual, version 2018.03.02.  Chapter 12 Reset Manager, Section 12.3 Reset Signals.
f2s_bridge_rst_n must have a footnote.  This footnote must state:  "Software must never reset this bridge.  This bridge must only be reset by POR/COLD/WARM reset."
Issue 543408:   Intel Stratix 10 Hard Processor System Programming Reference Manual, version 2017.11.06.  Page 7536, Section 2.31.10 i_rst_mgr_rstmgr.brgmodrst.fpga2soc description.
Change bit 2 “fpga2soc” description to the following: "Software must never write 0x1 to this bit. Software may only write 0x0 to this bit."
Resolution
No Workaround/Fix.
Under normal use cases, the software must write 0x0 to this bit to bring this bridge out of reset.  If a customer wants to reset this bridge, the customer must use POR or COLD, or WARM reset sequence.
Updated 2 months ago
Version 2.0
