Knowledge Base Article
Can the error-correction-code status ports be exported in the External Memory Interfaces Intel® Arria® 10 FPGA IP?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.2 and earlier, the error correction code (ECC) status ports in the External Memory Interfaces Intel® Arria® 10 FPGA IP are not exported eventhough the Export error-correction code (ECC) status ports option is enabled.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 1 month ago
