Knowledge Base Article
Can the checksum of a programming file be read without opening the Quartus II Programmer?
Description
Yes, the checksum of a SRAM Object File (.sof) file can be read from the Quartus® II Compilation Report.
The checksum of other programming files which are generated using the "Convert Programming Files..." utility can be read from Memory Map File (.map) file. The .map is generated automatically by the "Convert Programming Files..." utility.
Updated 2 months ago
Version 2.0
