Knowledge Base Article
Can the checksum be different if I'm reading the same programming file, but using different programmers?
Description
Yes, the checksum for the same programming file can be different depending on the programmer being used. The checksum calculations and algorithms can vary between third-party programmers, which results in different checksums for the same programming file. However, either programmer correctly programs the Altera device.
Updated 1 month ago
Version 2.0
