Knowledge Base Article
Can non-LVPECL clock buffer drive E-Tile Reference Clock input?
Description
Using E-tile, the reference clock termination specifies LVPECL, but the actual IO standard used will vary depending on the clock buffer used. For instance, the Intel® Stratix® 10 TX Signal Integrity (SI) Development Kit has two different clock buffers for the E-Tile reference clocks: Silicon Labs Si53311 uses LVDS while Si5341 uses a customized differential output. The recommendation is to have the clock buffer output meet the differential voltage and common mode voltage requirements in the Intel® Stratix® 10 Device Datasheet:
Link to Table 68. E-Tile Reference Clock LVPECL DC Electrical Characteristics
Resolution
The guidelines in the Intel® Stratix® 10 Device Datasheet and the E-Tile Transceiver PHY User Guide are applicable even if a non-LVPECL IO standard is being used. Observe the voltage requirements and include the QSF settings.
Updated 10 months ago
Version 2.0
