Knowledge Base Article
Can I use the SOF file generated from the implementation revision to perform the initial full chip configuration in a Partial Reconfiguration design?
Description
Yes, you can use any of the base or implementation compiled SOFs for the initial full chip configuration.
Resolution
All of the PR persona RBFs will be compatible with either the base SOF or any implementation SOF, as long as they are compiled with the same version of the Intel® Quartus® Prime Pro Edition Software and the same static QDB file.
Updated 1 month ago
