Knowledge Base Article
Can I use the Internal Oscillator setting of the Configuration Clock Source field for transceiver calibration on Intel® Arria® 10 and Intel Cyclone® 10 GX devices?
Description
No, you should not use the Internal Oscillator setting of the Configuration Clock Source field for transceiver calibration on Intel Arria 10 and Intel Cyclone 10 GX devices.
Resolution
For accurate calibration of Intel Arria 10 transceivers you should use the CLK_USR pin setting in the Configuration Clock Source field. You must also have the appropriate clock connected to the CLK_USR pin of the device on your PCB.
Updated 3 months ago
Version 2.0
