Knowledge Base Article
Can I use CvP Initialization Mode with Revision Design Flow in Arria 10 devices?
Description
No. Arria® 10 devices do not support CvP Initialization Mode with Revision Design Flow as well as CvP update mode. In Arria 10 devices, you need to reprogram your configuration ROM with the new periphery image even when you change only the core logic of your project.
CvP Initialization Mode with Revision Design Flow is supported in Arria V, Cylcone® V and Stratix® V devices only.
Resolution
Updated 2 months ago
