Knowledge Base Article
Can I use a 161 MHz clock for the Avalon-MM clock of the Intel® Stratix® 10 10GBASE-KR PHY IP Core?
Description
Yes, you can use up to a 161 MHz clock for the Avalon-MM clock of Intel® Stratix® 10 10GBASE-KR PHY IP Core.
Resolution
The Intel® Stratix® 10 Device Datasheet restricts the transceiver reconfiguration clock frequency to 125 MHz but the Intel® Stratix® 10 10GBASE-KR PHY IP Core is an exception.
Updated 3 months ago
