Knowledge Base Article
Can I run the Quartus® II programmer from the command prompt?
Description
Yes, you can run the Programmer separately at the command prompt or in a script by using the quartus_pgm executable. You may need to run the Assembler executable, quartus_asm, in order to produce a programming file before running the Programmer.For help on the quartus_pgm executable, type one of the following commands at the command prompt:
quartus_pgm -h (enter) quartus_pgm -help (enter) quartus_pgm --help= (enter)
Updated 3 months ago
