Knowledge Base Article
Can I route the Agilex™ 7 FPGA F-Series device out_refclk_fgt_[i] signal of the F-Tile Reference and System PLL Clocks FPGA IP to the FPGA core logic?
Description
No, you cannot route the Agilex™ 7 FPGA F-Series device out_refclk_fgt_[i] signal of the F-Tile Reference and System PLL Clocks FPGA IP to the FPGA core logic.
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3 and earlier, Quartus® Prime software will incorrectly compile designs that route the F-Tile Reference and System PLL Clocks FPGA IP out_refclk_fgt_[i] signal to the FPGA core logic. This signal is not intended for this purpose.
Resolution
To connect an Agilex™ 7 FPGA F-Series device reference clock to the FPGA core logic, you must use the out_coreclk_[i] port of the F-Tile Reference and System PLL Clocks FPGA IP.
This problem will be fixed in a future version of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
