Knowledge Base Article
Can I reprogram the volatile key after the key of Volatile Key with Tamper Protection Bit Set security mode is erased in Stratix® V/Arria® V/Cyclone® V devices?
Description
No. You cannot program any key if the Tamper Protection Bit is set.
Resolution
Ensure the required external battery VCCBAT is provided all the time if you use the Volatile Key with Tamper Protection Bit Set security mode.
This information is updated in the Stratix® V Device Handbook: Volume 1: Device Interfaces and Integration, Arria® V Device Handbook: Volume 1: Device Interfaces and Integration, and Cyclone® V Device Handbook: Volume 1: Device Interfaces and Integration to clarify.
Updated 1 month ago
