Knowledge Base Article
Can I read the value of an I/O pin, in core logic, when using the the Bus Hold feature?
Description
Yes, you can read the value of an I/O pin, in core logic, when using the the Bus Hold feature.
You should instantiate the pin as a bi-directional pin.  Using the Bus Hold feature will hold the contents of the output when it is no longer driven (tri-state), you can then read the input side of the bi-directional pin.
Resolution
Updated 2 months ago
Version 2.0
