Knowledge Base Article
Can I generate an EDIF Output File (.edo) using the Quartus™ software?
Description
The Quartus software generates the following output netlist files:
  • VHDL Output Files (.vho)
  • Verilog Output Files (.vo)
  • Standard Delay Format Output Files (.sdo)
The Quartus software does not generate EDO files since all simulation tools that work with the Quartus software support VHO and VO files.
Updated 3 months ago
Version 2.0
