Knowledge Base Article
Can I disable the HPS warm reset handling code in Preloader?
Description
Yes, the warm reset handling code can be disabled in the Preloader, if any of the following conditions is met:
- CSEL is set to 01, 10 or 11 and a fixed revision of the silicon is used.
- HPS cold and warm reset pins are tied together.
- BSEL is set to boot from FPGA.
For more information on the warm reset handling code patch see the related solution below.
Resolution
To disable the code follow the steps below:
- Edit the file uboot-socfpga\arch\arm\cpu\armv7\socfpga\spl.c to remove the call of the function ram_boot_setup(). This eliminates the restriction on the upper 4KB of OCRAM, which will now be available for the user.
- Recompile the Preloader.
Note: The Preloader does not behave differently on different silicon revisions of the SoC devices. This solution is applicable for all versions of silicon, including the ones where the HPS PLL lock issue is fixed.
For more information about the fixed silicon revisions, refer to the device errata sheet.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/es/es_arriav_es.pdf
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/es/es_cyclone_v.pdf
Related Articles
Updated 2 months ago
