Knowledge Base Article
Can I connect a single dedicated reference clock pin to 2 separate IOPLLs using the dedicated IOPLL clock path in an Intel Agilex® 7 FPGA or Intel® Stratix® 10 device?
Description
No, a single dedicated reference clock pin cannot connect to 2 separate IOPLLs using the dedicated IOPLL clock path in an Intel Agilex® 7 FPGA or Intel® Stratix® 10 device.
Resolution
To connect a single dedicated reference clock pin to 2 separate IOPLLs then you must either:
A) Use a global clock network for the 2nd IOPLL.
or
B) Cascade the 2 IOPLLs.
Updated 11 months ago
Version 3.0
