Knowledge Base Article
Can alternative Ra/Rb resistor values be used instead of those recommended by Altera even if they derive the same ratio, when using Enpirion EN5364 or EN5322 devices?
Description
No. Ra is part of the loopback circuitry of the Enpirion® EN5364 and EN5322 devices and therefore Altera® does not recommend deviating from the recommended resistor values that can be found in these device's respective datasheets.Updated 2 months ago
