Knowledge Base Article
Calibration Error Associated With Qsys Simulation Model Settings
Description
This problem affects DDR3 products.
Calibration failures have occurred in Qsys-based DDR3 designs with simulation model generation enabled. In failing cases, calibration does not complete successfully, and neither cal_success nor cal_failure is asserted.
Resolution
The work around for this issue is to not enable any simulation model when generating the synthesis file set.
This issue has been fixed.
Updated 3 months ago
Version 2.0
