Knowledge Base Article
Build Failure with Nios II Advanced Exceptions, MMU, and MPU
Description
Projects created in the Nios II IDE for an SOPC Builder system containing a Nios II processor configured with advanced exceptions, the memory management unit (MMU), or the memory protection unit (MPU) fail to build, and generate the following error messages:
ERROR - Classic build flow for Nios II system library does not support the Nios II advanced exceptions. Use the non-classic Nios II Board Support Package instead. <timestamp> - (SEVERE) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: com.altera.ingenuous.GTFElement.GTFElementErrorException: <error> element in GTF script make[1]: *** [system_description/../obj/system.h-t] Error 1 make: *** [system_project] Error 2
Resolution
Create the software project with the Nios II SBT command-line development flow. Alternatively, use the Nios II SBT for Eclipse.
Updated 1 month ago
Version 2.0
