Knowledge Base Article
BSP Editor Does Not Show Command-Line Help
Description
The following commands in the Nios II Command Shell should display command-line help:
  • nios2-bsp-editor --help
  • nios2-bsp-editor --extended-help
Instead, these commands launch the BSP Editor.
Resolution
For help with the BSP Editor, refer to “Using the BSP Editor” in the Getting Started with the Graphical User Interface chapter of the Nios II Software Developer’s Handbook.
Updated 1 month ago
Version 2.0
