Knowledge Base Article
Bonding Does Not Work for Multiple MPFE Ports in Hard Memory Controller
Description
This problem affects DDR2, DDR3, and LPDDR2 products.
In Arria V and Cyclone V devices, you can bond two hard memory controllers to increase their bandwidth. To use bonding, you must generate both hard memory interfaces with Export Bonding Interface turned on, and then connect the bonding signals between the two interfaces in the RTL code.
Bonding is supported only for hard memory controllers configured with one port. Do not use the bonding configuration when there is more than one port in each hard memory controller.
Resolution
There is no workaround for this issue.
For additional information, refer to Bonding Configurations and Parameter Requirements in the Functional Description - Hard Memory Interface chapter of the External Memory Interface Handbook, volume 3.
This issue will not be fixed.
Updated 1 month ago
Version 2.0
