Knowledge Base Article
BluePrint Platform Designer shows each physical cell of transceivers in only one logical hierarchy
Description
In the BluePrint Platform Designer, the locations of transceviers that you see in your design\'s logical hierarchy might be misleading. When multiple transceivers from different logical hierarchies are clustered into a single physical cell for placement, the BluePrint Platform Designer only shows this physical cell in one logical hierarchy, instead of in all the logical hierarchies associated with the transceivers.
Resolution
There is no workaround. This issue will be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 2 months ago
