Knowledge Base Article
Behavior Error when Disabling Data Generator/Checker Option in SerialLite III Streaming IP Core Design Example
Description
When you checked the Disable Data Generator/Checker option, the CRC error injection option will be enabled as well.
Resolution
You are advised not to use the Disable Data Generator/Checker option. There is no workaround. This issue will be fixed in a future release.
Updated 21 days ago
Version 3.0
