Knowledge Base Article
Audio Samples Missing from the Transmitted Stream
Description
When you use the DisplayPort TX core to send 1-channel to 8-channel audio in any channel count configuration (2 or 8), the audio samples will be regularly missing from the transmitted stream. This is due to the inefficient building of the audio sample packet. Not all samples read from the audio buffers get built into the packet.
Resolution
There is no workaround for this issue.
This issue is fixed in version 15.0 of the DisplayPort IP core.
Updated 3 months ago
Version 2.0
