Knowledge Base Article
ASI 10.1 Does Not Support Qsys
Description
You will not be able to generate the ASI MegaCore function v10.1 using Qsys. Adding the ASI MegaCore function in a Qsys system triggers the following warning message: ASI does not support Qsys-compatible generation
This issue affects all configurations.
The design will not generate successfully in Qsys.
Resolution
Use SOPC Builder instead.
This issue will be fixed in a future version of the ASI MegaCore function.
Updated 2 months ago
Version 2.0
