Knowledge Base Article
Arria 10 PowerPlay Early Power Estimator (EPE) Error: Input field "<CPU name> Frequency" has invalid value of <frequency>
Description
You will receive this error message when the VCCL_HPS is set to 0.95V and the frequency entered is more than 800MHz for Arria ®10 device speed grade -3.
Maximum HPS clock frequency for speed grade -3 at VCCL_HPS = 0.95V is 1000MHz. Likewise, maximum HPS clock frequency speed grade -3 at VCCL_HPS = 0.90V is 800MHz.
Resolution
This problem will be fixed in the future release of EPE.
Updated 2 months ago
Version 2.0
