Knowledge Base Article
Arria 10 EMIF IP for QDR-IV Using Address Inversion May Fail in Hardware
Description
If your Arria 10 EMIF IP for QDR-IV uses address inversion and targets the top-line performance specification, you might encounter failure in hardware, even though the IP compiles successfully.
Resolution
There is no workaround for this problem.
This problem will be fixed in a future version.
Updated 3 months ago
Version 2.0
