Knowledge Base Article
Arria 10 EMIF IP Does Not Support Qsys Testbench Generation Flow
Description
The Arria 10 EMIF IP is not compatible with the Qsys testbench generation flow. Generation of a Qsys testbench for Arria 10 EMIF IP will fail.
Resolution
The workaround for this problem is to manually instantiate the generated memory model (<instance_name>_mem_model.v/.vhd) in the Qsys-generated testbench (<instance_name>_tb.v/.vhd).
This problem will not be fixed.
Updated 1 month ago
Version 2.0
