Knowledge Base Article
Arria 10, Arria V GZ, and Stratix V PCI Express Designs using the Avalon-ST Interface that Acess the Transaction Layer Configuration Space Signals (tl_cfg_*) May Hang
Description
The Transaction Layer Configuration Space Signals data (tl_cfg*) driven by the Hard IP for PCI Express are incorrectly sampled in the FPGA fabric. Consequently, a setup or hold time violation may occur. The Quartus Prime software does not report the violation because this multi-cycle path is not constrained. If a timing violation occurs, the system may hang.
Resolution
For Arria 10 devices, use Quartus Prime 16.0.1 or later. The Transaction Layer Configuration Space Signals interface is held for eight coreclkout_hip cycles. Your Application Layer RTL must include code to sample this interface in the middle of the eight-cycle window. See the example RTL below:
//define register//
reg [3:0] cfg_addr_reg;
reg [3:0] captured_cfg_addr_reg;
reg [31:0] captured_cfg_data_reg;
reg cfgctl_addr_change;
reg cfgctl_addr_change2;
reg cfgctl_addr_strobe;
// detect the address transition
always @(posedge pld_clk or posedge reset)
begin
if (reset == 1\'b1) begin
cfg_addr_reg <= 3\'h0;
cfgctl_addr_change <= 1\'h0;
cfgctl_addr_change2 <= 1\'h0;
cfgctl_addr_strobe <= 1\'h0;
end else begin
cfg_addr_reg[3:0] <= tl_cfg_int_add[3:0];
// detect address change
cfgctl_addr_change <= cfg_addr_reg[3:0] != tl_cfg_int_add[3:0];
// delay two clock and use as strobe to sample the input 32-bit data
cfgctl_addr_change2 <= cfgctl_addr_change;
cfgctl_addr_strobe <= cfgctl_addr_change2;
end
end
// captured cfg ctl addr/data bus with the strobe
always @(posedge pld_clk)
if(cfgctl_addr_strobe)
captured_cfg_addr_reg[3:0] <= tl_cfg_int_add[3:0];
captured_cfg_data_reg[31:0] <= tl_cfg_int_ctl[31:0];
end
For Arria 10 devices, you must add the following timing constraints in your Synposys Design Constraints (SDC) file.
set_multicycle_path -setup -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:altpcie_a10_hip_pipen1b|wys|tl_cfg_add[*]}] 2
set_multicycle_path -hold -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:altpcie_a10_hip_pipen1b|wys|tl_cfg_add[*]}] 2
set_multicycle_path -setup -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:altpcie_a10_hip_pipen1b|wys|tl_cfg_ctl[*]}] 2
set_multicycle_path -hold -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:altpcie_a10_hip_pipen1b|wys|tl_cfg_ctl[*]}] 2
For Stratix V and Arria V GZ devices, you must add the following timing constraints in your Synposys Design Constraints (SDC) file.
set_multicycle_path -setup -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:stratixv_hssi_gen3_pcie_hip|tl_cfg_add[*]}] 2
set_multicycle_path -hold -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:stratixv_hssi_gen3_pcie_hip|tl_cfg_add[*]}] 2
set_multicycle_path -setup -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:stratixv_hssi_gen3_pcie_hip|tl_cfg_ctl[*]}] 2
set_multicycle_path -hold -through [get_pins -compatibility_mode -nocase {*|altpcie_a10_hip_pipen1b:stratixv_hssi_gen3_pcie_hip|tl_cfg_ctl[*]}] 2
Updated 2 months ago
Version 2.0
