Knowledge Base Article
Are time-limited SOF files prohibited from being converted to other programming file types?
Description
Yes, time-limited SOF (.sof) files are prohibited from being converted to any other programming file format since this would remove the time limited nature of the file. For conversion from a SOF to any other programming file format you will need to use a .sof that does not have any time-limited or OpenCore megafunctions within it. If you do you will need to license the core or megafunction and recompile to generate a SOF file that is not restricted.
Updated 1 month ago
