Knowledge Base Article
Are there any known issues with the Altera PLL Reconfig IP for Arria 10, Stratix V, Arria V or Cyclone V devices which may cause reconfiguration to occasionally fail?
Description
Yes there is an issue with the Altera® PLL Reconfig IP for Arria® 10, Stratix® V, Arria V and Cyclone® V devices in Quartus® Prime software versions prior to 16.1,
In this IP there is a lack of synchronization of the locked signal, which is an asynchronous signal sourced from the PLL that is being reconfigured. This runs the small risk of causing a malfunction of the reconfiguration control state machine that the locked signal feeds, which operates in the mgmt_clk domain. This may result in a reconfiguration request to fail.
Resolution
This issue is fixed in Quartus Prime software version 16.1.
Updated 1 month ago
