Knowledge Base Article
Are there any alternative flash memory devices equivalent to the Micron P30/P33 Parallel NOR flash memory devices to support Active Parallel configuration scheme?
Description
No, there are no alternative flash memory devices equivalent to the Micron P30/P33 Parallel NOR flash memory devices to support Active Parallel configuration scheme in Cyclone® III and Cyclone® IV devices.
Resolution
Due to the End Of Life (EOL) Micron P30/P33 Parallel NOR flash memory devices, you are advice to consider redesigning your boards using either Active Serial, Passive Serial, or Fast Passive Parallel configuration scheme.
Updated 2 months ago
