Knowledge Base Article
Are the 64b/66b header bits compliant to the IEEE802.3ae standard when using Enhanced PCS with Basic mode in the L-Tile/H-Tile Transceiver Native PHY Intel® Stratix® 10 FPGA IP and Transceiver Native PHY Intel® Arria® 10/Cyclone® 10 FPGA IP?
Description
No, the 64b/66b header bits are not compliant with the IEEE802.3ae standard when using Enhanced PCS with Basic mode in the L-Tile/H-Tile Transceiver Native PHY Intel® Stratix® 10 FPGA IP and Transceiver Native PHY Intel® Arria® 10/Cyclone® 10 FPGA IP.
The IEEE802.3ae standard requires the header to be sent and received LSB first, with the control indication bit placed at bit[0].
Instead, the header bits are sent as MSB first when using in the L-Tile/H-Tile Transceiver Native PHY Intel® Stratix® 10 FPGA IP and Transceiver Native PHY Intel® Arria® 10/Cyclone® 10 FPGA IP in Enhanced PCS with Basic mode.
The L-Tile/H-Tile Transceiver Native PHY Intel® Stratix® 10 FPGA IP and Transceiver Native PHY Intel® Arria® 10/Cyclone® 10 FPGA IP are fully compliant with the IEEE802.3ae standard when configured in 10Gbase-R mode.
Resolution
To work around this problem in Enhanced PCS with Basic mode, you can implement the following:
  • For the transmit direction: Delay the tx_ parallel_data by one clock cycle with respect to the tx_control data.
  • For the receive direction: Delay the rx_control data by one clock cycle with respect to the rx_data.
 You can refer to the following code as an example.
This problem does not affect IEEE802.3ae compliance with Intel transceiver protocol IPs that don't use Enhanced PCS with Basic Mode.
Updated 11 months ago
Version 2.0
