Knowledge Base Article
Any top or bottom central PLL in Stratix V ES devices that has its reference clock fed by a clock network should not be fed a clock faster than 400 MHz
Description
Any top or bottom central PLL in Stratix V ES devices that has its reference clock fed by a clock network should not be fed a clock faster than 400 MHz.
Resolution
If possible, directly feed the reference clock from a pin or manually place the PLL on the left or right side.
Updated 3 months ago
