Knowledge Base Article
Analysis and Synthesis generates errors if you instantiate an ALTGX instance with the GIGE protocol
Description
If you instantiate an ALTGX instance with the GIGE protocol
and compiled, Analysis and Synthesis generates errors similar to
following:
Error: gige_alt4gxb:gige_alt4gxb_component|receive_pcs0 parameter
Rate match pattern 1 of 0 has a length of 1, which does not match
its corresponding Size of the rate_match_pattern1 and rate_match_pattern2
parameters of 20
parameter Rate match pattern 2 of 0 has a length of 1, which does
not match its corresponding Size of the rate_match_pattern1 and
rate_match_pattern2 parameters of 20
Resolution
To correct the mismatched settings. activate the validator by changing the number of channels (or any other setting) in the ALTGX MegaWizard interface.
Updated 2 months ago
