Knowledge Base Article
ALTFP_ATAN megafunction incorrectly ties its clock enable port to ground
Description
In the ALTFP_ATAN megafunction, the clk_en port
is incorrectly tied to ground if you do not enable the port in the
MegaWizard Plug-In Manager.
Resolution
In the ALTFP_ATAN MegaWizard Plug-In Manager, enable the clk_en port
and either tie it to VCC or control the port as required for your
design.
This issue is corrected in the Quartus II software version 12.0 SP1.
Updated 2 months ago
