Knowledge Base Article
Altera PHYLite for Parallel Interfaces IP Core GUI Shows Unsupported Input OCT Values
Description
Input OCT Values for the following I/O standard are not supported in Arria 10 devices.
  • SSTL-125: 20 Ohm with calibration
  • SSTL-135: 20 Ohm with calibration
  • SSTL-15: 20 Ohm with calibration
If you select any of these values in the parameter editor, your design will not meet the calibration accuracy specification of -10 to 40%.
Resolution
Do not select these values.
This issue will be fixed in a future version of the Altera PHYLite for Parallel Interfaces IP core.
Updated 18 days ago
Version 2.0
