Knowledge Base Article
Altera DisplayPort Auxiliary Protocol Not Compliant to DisplayPort Specifications
Description
The DPTX and DPRX AUX channels may fail to receive correct replies for DPTX or requests for DPRX. This issue occurs when you generate the connected device AUX channel data with a period shorter than 472 µs or larger than 529 µs. The DisplayPort specifications allow for a period within the range of 400 µs to 600 µs.
Resolution
There is no workaround for this issue.
This issue is fixed in version 15.1 of the DisplayPort IP core.
Updated 2 months ago
