Knowledge Base Article
Active-High Reset Even If You Select Active Low Reset
Description
Some blocks continue to use active-high reset, even if you select active-low reset..This issue affects all designs that use the following blocks:
- List
- ForLoop
The design fails
Resolution
To work around the issue, do not select active-low reset. This problem is fixed in DSP Builder v13.1.
Updated 28 days ago
