Knowledge Base Article
A CDR locked signal might not be stable when using serial loopback mode when simulating a Custom PHY IP for Stratix V
Description
When you simulate a Custom PHY IP, a CDR locked signal might not be stable when using serial loopback mode.
Resolution
Disable serial loopback mode and use an external serial loopback in the testbench.
Updated 3 months ago
Version 2.0
