Knowledge Base Article
9.8G CPRI IP Core Variations That Target an Arria V GZ Device Do Not Achieve Timing Closure
Description
CPRI IP core variations with a CPRI line rate of 9.8 Gbps that target an Arria V GZ device fail to achieve timing closure with the default Quartus II Fitter settings. Specifically, they experience hold time violations on the PCS-PLD path and setup time violations on the PLD-PCS path.
Resolution
To achieve better timing closure results, perform the following actions:
- To avoid the hold time violations on the PCS-PLD path, turn off register packing along this path in the Quartus II Fitter settings, by adding the following assignments:
- To avoid the setup time violations on the PLD-PCS path, add
set_max_delayassignments to overconstrain timing.
set_instance_assignment -name AUTO_PACKED_REGISTERS_STRATIXII
OFF -to *gen_cpri_rx*buf_wr_data*
OFF -to *gen_phy_loop*buf_wr_data*
This issue will be fixed in a future version of the CPRI MegaCore function.
Updated 2 months ago
