Knowledge Base Article
50G Interlaken IP Core Does Not Support Selection of Two Calendar Pages
Description
The 50G Interlaken IP core does not support the selection of two calendar pages. If you select the value of 2 for the Number of calendar pages parameter, the 50G Interlaken IP core does not set and reset the Reset Calendar bit in the Interlaken control words as expected.
Resolution
This issue has no workaround.
This issue is fixed in version 13.0 SP1 of the 50G Interlaken MegaCore function.
Updated 1 month ago
Version 2.0
