Knowledge Base Article
50G Interlaken IP Core Does Not Support 200 MHz _usr_clk Clocks
Description
The 50G Interlaken IP core does not support user clocks (rx_usr_clk and tx_usr_clk) with
frequency less than 250 MHz. If you provide an input tx_usr_clk clock
whose frequency is less than 250 MHz, the IP core will experience
internal FIFO underflow, which is flagged with the itx_hungry and itx_underflow flags.
If you provide an input rx_usr_clk clock whose frequency
is less than 250 MHz, the IP core will experience internal FIFO
overflow and data loss from the Interlaken link.
Resolution
This issue has no workaround.
This issue is fixed in version 13.0 SP1 of the 50G Interlaken MegaCore function.
Updated 1 month ago
