Knowledge Base Article
40-100GbE MAC and PHY IP Core MegaCore Function User Guide Lists Wrong Module Names in Resource Utilization Tables
Description
In the 40- and 100-Gbps Ethernet Mac and PHY MegaCore Function User Guide, the resource utilization numbers for 40GbE variations appear correctly in the tables, but the module names in the tables are 100GbE variation module names. The correspondence is clear and the resource utilization numbers are accurate.
Resolution
This issue has no workaround. When you read the 40GbE resource utilization numbers table in the user guide, interpret the module names as 40GbE module names.
This issue is fixed in version 13.1 of the 40- and 100-Gbps Ethernet MAC and PHY MegaCore Function User Guide.
Updated 1 month ago
