Knowledge Base Article
13.0 Quartus II NativeLink simulation fails for Stratix V devices when Generate Value Change Dump (VCD) is selected
Description
In the 13.0 Quartus® II software release, NativeLink simulation for Stratix® V devices does not allow Value Change Dump (VCD), but this option is selectable under the EDA Tool Settings > Simulation window. If you select Generate Value Change Dump (VCD) file script and Compile test bench, NativeLink generates a .do file with the extension <*>_run_msim_gate_verilog.do. This file contains <*>_dump_all_vcd_nodes.tcl which causes the simulation to fail. There is no error or warning message to report the error.
Resolution
This issue is fixed in the 13.0 Quartus® II software release service pack 1.
To compile your design, do not select Generate Value Change Dump (VCD) file script, or remove the <*>_dump_all_vcd_nodes.tcl file from <*>_run_msim_gate_verilog.do.
Updated 29 days ago
Version 2.0
