Knowledge Base Article
100G Interlaken MegaCore Function User Guide Provides Insufficient Information to Connect Arria 10 TX PLL
Description
According to the 100G Interlaken MegaCore Function User Guide, user logic should drive the tx_pll_locked input signal to an Arria 10 100G Interlaken IP core with the logical AND of the pll_locked output signals of the Arria 10 TX PLL IP cores. However, this information is incomplete. The input signals to the logical AND should also include the inverse of each TX PLL pll_cal_busy signal.
For illustration in the case of a single external TX PLL, refer to Figure 5-3, Arria 10 PLL to Arria 10 100G Interlaken MegaCore Function Connection Diagram, in the "Migrating 100G Interlaken IP Core from Stratix V to Arria 10 Devices" chapter of the Arria 10 Migration Guide.
Resolution
This issue has no workaround. Ensure you connect the Arria 10 external TX PLLs to your 100G Interlaken IP core according to the instructions in this erratum.
This issue is fixed in version 14.1 of the 100G Interlaken MegaCore Function User Guide.
Updated 3 months ago
Version 3.0
