Knowledge Base Article
100G Interlaken IP Core itx_chan Signal Must Be Held Steady for the Duration of the Packet
Description
User logic must hold the 100G Interlaken IP core itx_chan signal
steady for the duration of the packet on the TX user data transfer
interface, from the time user logic asserts the itx_sop signal
through the cycle in which it asserts the itx_eop signal.
Resolution
This issue has no workaround. User logic must ensure that
the itx_chan signal behaves as described.
This issue is fixed in version 13.1 of the 100G Interlaken MegaCore function.
Updated 27 days ago
