Knowledge Base Article
(# WARNING[1]: <file name>(): No default binding for component: "scfifo". (Generic "maximize_speed" is not on the entity)
Description
This warning message may occur when a MegaWizard®-generated DCFIFO design from the Quartus® II software version 4.0 is compiled in the Modelsim® simulator.If you choose Yes (Best speed) under Output register option for devices with fully synchronous RAM on page 7 of the MegaWizard when generating the FIFO, the ModelSim software issues the compilation warning.
To avoid this warning message with the Quartus II software version 4.0, comment out the maximize_speed and optimize_for_speed parameters/generics in the MegaWizard-generated file. In addition, create and define a value for lpm_widthu for the SCFIFO instance.
Here is an example of modified code inside a VHDL MegaWizard-generated output file:
COMPONENT scfifo
GENERIC
ALLOW_RWCYCLE_WHEN_FULL: STRING := "OFF";
ALMOST_EMPTY_VALUE: NATURAL := 0;
ALMOST_FULL_VALUE: NATURAL := 0;
LPM_NUMWORDS: NATURAL;
LPM_SHOWAHEAD: STRING := "OFF";
lpm_width: NATURAL;
lpm_widthu: NATURAL; -- Altera edit
--MAXIMIZE_SPEED: NATURAL := 5; -- Altera edit
--OPTIMIZE_FOR_SPEED: NATURAL := 5; -- Altera edit
OVERFLOW_CHECKING: STRING := "ON";
UNDERFLOW_CHECKING: STRING := "ON";
USE_EAB: STRING := "ON";
lpm_type: STRING := "scfifo"
and
scfifo14 : scfifo
GENERIC MAP (
LPM_NUMWORDS => 3,
LPM_SHOWAHEAD => "OFF",
lpm_width => 32,
lpm_widthu => 2, -- Altera edit
OVERFLOW_CHECKING => "ON",
UNDERFLOW_CHECKING => "ON",
USE_EAB => "OFF)
This problem has been fixed in the Quartus II software version 4.0 SP1.
Updated 1 month ago
