Knowledge Base Article
*** Fatal Error: Uncaught C Exception Module: quartus_fit.exe
Description
You may see this error when compiling your design in the Quartus® II software if your computer does not have sufficient memory to compile the design.
Resolution
To avoid this error, ensure your computer has enough memory to compile your design based on the guidelines in the Device Support Release Notes.
Updated 2 months ago
